Retaining rings and washers
Retaining rings
Mode
Tool
Tool set
Retaining Ring
Fasteners
Multiple retaining ring and retaining washer tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a retaining ring:
Click the tool and mode.
Parameter
Description
Type
Select the retaining ring type
ASME
DIN
Size (mm)
Select the retaining ring size in millimeters
View
(2D only)
Select the 2D view
Place Locus at Center
Adds a locus at the center of the retaining ring
Retaining washers
